Attribute Tables Not Opening
2921
03-22-2018 08:27 AM
MikeEdwards
Attribute tables are not opening in ArcGIS Pro. I'm running version 2.1.2.
When I right click the data set in my Contents window and select Attribute Table nothing happens. I tried using Crtl+T and again nothing happens. I've checked both monitors I'm using and the tables aren't opening on my second monitor.
If I try to select a feature and view the attributes for the selected feature Pro crashes without prompting me with an error.
It doesn't matter the format of the data either. Shapefile, feature class, etc all result with no attribute table and crashing.
Has anyone else experienced this?
DanPatterson_Retired
sounds like a faulty installation if you are getting crashes.  If it worked at one time and doesn't work on other projects or new projects, then it could be that one project, but if it persists on any/all projects, time for a reinstall/repair
MikeEdwards
I gave both those a try and nothing. Still having the issue.
