Grid resolution and terrain analysis
818
03-21-2018 10:51 AM
nolumanyanocamagu
Hi there!
I want to calculate the ideal grid size for a contours_area.shp layer.
I will use one of Hengl's formula for calculating grid resolution.
To get the grid resolution the area Hengl's formula states that I should divide the total size of the study area and
the total cumulative length of all digitized contours.
How do I determine the total cumulative length of all digitized contours?
XanderBakker
Esri Esteemed Contributor
You mention you have a shapefile (contours_area.shp). If would be better to import the shapefile into a file geodatabase. When you import it into a FGDB the system will automatically manage a field called Shape_Length. You can use simple field statistics to obtain the sum of all the lengths. If you don't want to or cannot load your shapefile into a FGDB, you can use Add Geometry Attributes—Help | ArcGIS Desktop
