Hi community
Would you be able to help me control the visible information shared from a survey when shared by everyone (the public). At the moment sensitive and irrelevant results are shared with the public such as telephone numbers (sensitive).
I have switched them off in the "analyse / set visibility" and removed them from the "data/report beta template". But when I view from the "Survey Results Link", these fields remain visible.
Is there any other place I should switch off these fields?
Thanks - David
Solved! Go to Solution.
Hi Gents
Thanks for the suggestions. They definitely made me look at different ways to solve the problem. I think you both assume too much ability on my part. The solution for me was to go to ArcGIS online, load my file from the web, then in the file go to More options>Set view definition>Define fields, switch off those not to be viewed and then resave the file. When viewed from the survey results, the "off" fields indicate that these data are not available.
Again, many thanks
Hi Kabelo,
If you are sharing the survey results and want to restrict the fields, you will need to modify the _stakeholder view of the data to remove the fields. See Manage hosted feature layers—ArcGIS Online Help | ArcGIS for more information.
Maybe a simpler way is to set a View for the hosted feature layer (Create hosted feature layer views—ArcGIS Online Help | ArcGIS ), where you can hide all fields with sensitive content and insert in your pubblic map: Define fields, features, or an area of interest for hosted feature layer views
Cheers
Stefano
Hi Gents
Again, many thanks
