Near Me widget - Result List tooltip
1462
03-16-2018 01:54 PM
NataliyaLys
I am using near me widget in WAB. To achieve a desired formatting of the text in Result List I added a basic html formatting to the pop-up tile of the searchable layer in my web map. It worked just the way I wanted to display results, but the tool tip shows raw html text. I would like to change a text of the tool tip, or remove the tool tip all together. I looked thought the code, but I just cannot figure out how to do it. Any help would be greatly appreciated. Thank you.
RobertScheitlin__GISP
Nataliya,
   If you are using the developer version then you can comment out the code that set the tooltip.
In the widgets item-list.js file @line 644 comment out:
domAttr.set(divItemName, "title", value);
Nataliya,
NataliyaLys
Robert,
That's exactly what I needed. Thank you.
