Adding Z values to an existing polygon
8797
03-16-2018 10:11 PM
janehansen
Hi I have been asked to include a z value for polygons which have already been created. Is this possible, and is it possible to add z values when there are no elevation or vertical values in the attribute table?
Thank
Jane
DanPatterson_Retired
You can't retro-fit an existing featureclass, but you probably could create a new one and copy the existing 2D geometry over and define how z is to be assigned
http://pro.arcgis.com/en/pro-app/help/editing/create-polygon-features.htm
http://pro.arcgis.com/en/pro-app/help/editing/specify-an-elevation-for-3d-features.htm
beyond this some operations that require a z value simply need a field in the attribute table.  You would have to provide values for it but that field can be used for such things as extruding polygons.
janehansen
Thanks once again for your help Dan. Very helpful!
Jane
XanderBakker
Esri Esteemed Contributor
In case you would be interested in doing some python coding, I have a blog post here that explains how to set Z values: https://community.esri.com/people/xander_bakker/blog/2016/07/08/working-with-3d-and-m-aware-geometri...
