Attribute Table Appearance Options?
5094
03-16-2018 09:24 AM
DalindaDamm
I was wondering if there is a way in ArcGIS Pro to alter the general appearance of attribute tables? I know you can do this within a Table Frame that has been added to a Layout via the Format Table Frame pane. This question specifically pertains to viewing a table in the regular 'table dialog window'.
In ArcMap, you could alter various font details, size of cells, etc. within either a particular attribute table (Table Options > Appearance), or all attribute tables in a map document (Customize menu > ArcMap Options > Tables tab). I know this option can be important for folks who need to make fonts larger for better readability, or to alter color schemes to assist with colorblindness.
DanPatterson_Retired
for readability, you can certainly scale the fonts...
DalindaDamm
I totally missed that in all my poking around. Thanks!
GabrielScarcella
I would like to know if in recent versions of ArcGIS Pro is a way to modify the font face and size. For example, to set a monospaced typeface.
