Update records of related table
2727
03-19-2018 04:06 AM
SMauri
Hi all,
I'm tring to update record from a related table (Ispezioni) with attachments
In this table I woulkd like to insert a new inspection, but also update an existing one if necessary.
According to documentation for editing existing data (Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS ) I set key value in "esri:parameters" column like in image below
Unfortunately when I open my asset from inbox (with a query) I can see all questions from feature class table, but not from related table (date and select_one questione type)
Survey123 App 1
And of course yes, there is almost one inspection for every asset (image below is the same of that inspected with Survey123)
Any suggestion?
Thank you
Stefano
by Anonymous User
Not applicable
Hi Stefano,
You need to put the allowUpdates=true parameter on the begin repeat field, not on each of the questions in the repeat.
Regards,
Phil.
by Anonymous User
Not applicable
Hi Stefano,
Regards,
Phil.
SMauri
Hi Philip, thank you for your answer.
Unfortunately no data appears also after putting parameter in right place...any idea?
I put my form as attachment and let me now if you need to access to my map for some test.
Cheers
Stefano
SMauri
Ok solved...I missed to insert key word "query" as parameter...
Thank you
