ArcGIS Solutions Deployment Add-In: 407 Proxy Error
991
03-14-2018 12:47 PM
MarkCederholm
I'm trying to use the ArcGIS Solutions Deployment Add-In, but when I try to deploy a solution, I get this error:
<urlopen error Tunnel connection failed: 407 Proxy Authentication Required>
Update:  I tried setting the http_proxy and https_proxy environment variables, as I would for pip, and that did the trick.  I'm willing to bet that this is a Python issue.  I thought all this stuff was fixed.
Update 2:  I also had to set the environment variables in order to see and download untools.
