KeyError when working with fields
4985
03-13-2018 10:50 AM
VishalShah2
I get KeyError: 5 error when running my script tool.
Background of the script:
Earlier in the script, i do a summary statistics and I am editing the fields to get the field alias so the output looks cleaner because later in the script, table to excel is run to export the table. Here is what my script looks like:
fieldList = arcpy.ListFields(in_table)
length = len(fieldList)
arcpy.DeleteField_management(in_table, nodeIDField)
alias_dict = {1: 'Network ID', 2: 'Project ID', 3: 'Municipality', 4: 'Node Count'}
for i, field in enumerate(fieldList):
    if field.type != 'OID':
        newfield = '{}new'.format(field.name)
        arcpy.AddField_management(in_table, newfield, field.type, field.precision,
                                field.scale, field.length, alias_dict[i], field.isNullable, field.required, field.domain)
        arcpy.CalculateField_management(in_table, newfield, '!{}!'.format(field.name), "PYTHON_9.3")
        arcpy.DeleteField_management(in_table, field.name)
When running this, the existing fields do get modified with the alias I want for each, but then get KeyError: 5 error. My thought is that it is because the key 5 does not exist. How do I get the script to just pass through to the next portion of the script if the key of 5 does not exist?
VishalShah2
Never mind. I found a working solution.
nodeIDField = "COUNT_ID"
length = len(fieldList) - 2
    if field.type != 'OID' and i <= length:
The original length of the fieldlist was 6, hence why i got KeyError: 5. It was looking for the 5th key in the dictionary. I am subtracting 2 because I do not want to count the ObjectID field or the field I am deleting using arcpy.DeleteField_management.
VishalShah2
JoshuaBixby
MVP Esteemed Contributor
If the field isn't in your alias list, do you want it created with no alias or not even created at all?
VishalShah2
Not created at all.
