Creating a Polygon
3603
8
03-05-2018 06:53 AM
JohnMcConalogue
A surveyor wants to be able to draw an area in the shape of a polygon when they are creating a survey.
Is it possible to create a polygon of the area you are surveying?
Thanks.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi John,
Currently you cannot draw on a map.  We will be enhancing the annotate appearance of the image control to allow for map capture over the next few releases.
RobertBorchert
Honored Contributor
You will need include more details.
Like what is your survey person using?  Where do they want to do this, in the field or office. etc.
A universal answer at this time is yes you can draw polygons.
JohnMcConalogue
They are using a Tablet with Survey123 installed which is sending the collected data to AGOL.
They are using this in the field.
Can they draw lines and polygons using Survey123 on a Tablet in the field?
RobertBorchert
Honored Contributor
No.
Survey123 is designed for you to create simple to complex data collection forms in the office that can be taken out in the field and it does allow you to create a geopoint that can  be brought  back into ArcGIS
JohnMcConalogue
Robert I know this and we already do this.
What I am asking is there any way that when the surveyor is in the field, using the pre-created survey, can they draw a polygon on a map to denote a piece of land that they are surveying?
JamesTedrick
Hi John,
JohnMcConalogue
Thanks James
DougBrowning
MVP Esteemed Contributor
Why not draw the Polygon in Collector then launch Survey123 via a URL to keep them linked?
Just an idea.
JohnathanHasthorpe
Polyline and polygon support is now available in beta. Please go to the EAC site to start testing!: Welcome to our Feedback Community
