Using URL Scheme to launch non-esri application from survey123
1406
03-02-2018 02:15 PM
Jean-YvesLandry1
Is this possible?
for example launching qr code reader from Zxing:
<a href="intent://scan/#Intent;scheme=zxing;package=com.google.zxing.client.android;end"> Take a QR code </a>
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Jean-Yves,
To my knowledge, opening an application with that URL pattern would likely not work; you should use the pattern of of the app's URI (i.e., zxing:// ... ).
That being said, is there an issue with teh built-in bar code scanning that is causing you to favor zxing ?
Jean-YvesLandry1
Hi James,
no problem with the built-in bar scanning per se simply a code example...
The idea would be to connect to a scanner type app (i.e. camscanner), take a picture of all the pages of the document, make a pdf document, then somehow send it back as an attachment for survey123, or attach it manually.
At the moment we've been using image on a repeat.
I'm open to suggestions...
