Distortion in Text when exporting a map
6097
9
03-01-2018 08:38 AM
janehansen
Hi I am creating a series of maps and need to export them in a format that can be inserted into a word doc.  I have been using Jpeg and when I export the map my client sees the Text (Title, legend information) as a bit blurry.  I am using arial font not bold. I have tried different fonts but still get the blurriness.  A friend of mine exported a similar map using Qgis  jpeg format and it was much less blurry.
I am hoping for some guidance on how to reduce the blurriness. Thanks Jane
MitchHolley1
What happens if you export as a PDF?
JosephCarter
I agree with Mitch. . . .export to PDF. Open the new PDF and FILE/Save as other/Picture/JPEG. Name the file. Open your word doc. and Insert/picture the new JPEG. Tip: if you will use this file often. Place it into your stamp tool in Adobe (create custom stamp). I will be available always. .
janehansen
I'll give this a try, I can export as PDF and it looks good. Just couldn't
insert it into word. I will try saving the PDF as a jpeg.
janehansen
Hi Joseph, I exported the map as a pdf but when I went to save the pdf  as a 'save as' jpeg the only option available in the drop down was pdf. Have  you saved a pdf as a jpeg before? If so can you explain what I am missing?
CoryMacNeil1
Hi Jane,
In the Export Map window, have you tried increasing the JPEG Quality under the "Format" tab?
I hope this helps,
Cory
janehansen
Thanks for your input Cory, the quality was on high.
Jane
AbdullahAnter
Honored Contributor
What is size of the page on layout ? and what the size of the print paper size?
What is resolution number of export JPEG?
janehansen
Hi thanks for your help Abdullah. The map is in layout, size of print paper
is letter, and I have tried different dbi, 600 looks best but is still
blurry.
Jane
AbdullahAnter
Honored Contributor
Because you will export the map as JPEG and not print directly from ARCMAP,  I see there is no problem if you enlarge your map size in layout to A3 .
try it and see if it still blurry or solved.
