Converting Raster Data Typ
4220
11
03-01-2018 07:44 AM
JonasDanner
Good day,
I'm using an external Toolbox in my current analysis. One of the inputs has to be a short integer grid, containing values of "0" and "1". But the field type of the Raster I currently have (Tif-Format) is a long integer. I already tried to add a short integer field in the attribute table and used the field calculation. But the Input raster for the toolbox can not have another column then the short integer value. If I use the tool "delete field" to delete the long integer field, the geographical information gets lost, as this is the main value field. Do you know how I can convert the long into short integer values, od how can I create a new raster with short integer values?
Thanks in advance,
Jonas
XanderBakker
Esri Esteemed Contributor
If you have Desktop (ArcMap or ArcGIS Pro) and the Spatial Analyst extension you could use the Raster Calculator—Help | ArcGIS Desktop , and calculate something like this :
Con("YourRaster" == 1, 1, 0)
If you point the output to a TIF file, it will create an 8 bit unsigned integer:
You can't change the field type of the value field of a raster, since this is defined by the raster type.
SteveLynch
use CopyRaster
JonasDanner
ok, thank you! That means, if I have to have a short integer grid as Input, it can't be a Tiff-raster, but has to be something else?
SteveLynch
No, the new output raster can be any format that supports short int. You decide on the Pixel type.
JonasDanner
hm, I don't really understand it ... I open copy raster, Input raster is my 8-bit signed, long-integer tiff-raster. I name the output raster dataset "myraster.tif". I choose 4 bit. It executes and loads the result into the dataset. but when I'm checking the properties of the new raster it's 8-bit unsigned. and if I check the field properties in my attribut table it still says Type: Long
SteveLynch
Are the values in your input raster in the 4 bit range?
JonasDanner
I forgot that it was not only my values, but also a "count"-column, thats why... so I trid it again, now its a 4 bit unsigned raster. but still, the field properties in my attribut table is Type: Long... that's what I have to change
SteveLynch
Only way that (I can think of) to do that is to add a short field to the table and then use CalculateField to update the values. To get this newly created field as the primary value field you’ll need to use the Lookup<http://desktop.arcgis.com/en/arcmap/10.3/tools/spatial-analyst-toolbox/lookup.htm> tool.
JonasDanner
Thank you very much for your help! But sadly that doesn't work, as the lookup tool makes it a long-integer again...
