Can I return feature layersfrom a function?
1713
02-28-2018 08:21 AM
Zeke
Honored Contributor
I'm creating 3 feature layers in one function. I'd like to return them from the function in a list, but as I expected, their type in the list is just string. I know I can save them out as a lyr file, but trying to avoid that if possible. Maybe they go out of scope when the function ends? Thanks.
def makeFeatureLayers():
    Make feature layers from Annotation, Polygon and Points features
    print("\nCreating feature layers")
    anno = 'Annotation'
    pt = 'Point'
    poly = 'Polygon'
    anno_path = os.path.join(ds_path, anno)
    pt_path = os.path.join(ds_path, pt)
    poly_path = os.path.join(ds_path, poly)
    fc_dict = {}
    fc_dict[anno] = anno_path
    fc_dict[pt] = pt_path
    fc_dict[poly] = poly_path
    fc_list = []
    for k, v in fc_dict.iteritems():
        lyr_name = k + '_lyr'
        try:
            arcpy.MakeFeatureLayer_management(v, lyr_name)
            fc_list.append(lyr_name)
        except Exception as e:
            print("\nError: {}".format(e))
            print(arcpy.GetMessages(2))
    for fc in fc_list:
        print("\nType of fc: {}".format(type(fc)))
JamesMacKay3
Use the getOutput() method on the MakeFeatureLayer result:
lyr = arcpy.MakeFeatureLayer_management(yourLayer).getOutput(0)
JoshuaBixby
MVP Esteemed Contributor
Even using James' suggestion, you will be returning a reference to those layers and not the layers themselves.  Whether having a list of feature layer references will work for you depends on how exactly the code snippet is used in the larger workflow.  Can you elaborate on how the code snippet is being used, i.e., run in a stand-alone script, run as part of a ArcGIS Tool, etc....
JamesMacKay3
Good point, another way would be to ditch MakeFeatureLayer and use arcpy.mapping.Layer instead.
Zeke
Honored Contributor
This is part of a script. The layers are needed because I'm applying definition queries to them and then using them in a spatial join. The basic process is to assign annotation text to the polygon containing it, then assign the text to points within the polygon.
