Setting Field Value as Default in a Repeater
1553
02-23-2018 04:07 AM
JohnMcConalogue
I have a drop-down list with 3 values and I want to set one value to be default, I can do this but it seems no to work when the field is within a Repeater.
How can I do this within a Repeater?
Thanks.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi John,
I'm able to set a default value for a select_one within repeat section successfully.  Can you provide the example that does not work?
JohnMcConalogue
Here is example that doesn't work.
The highlighted line is the field I am trying to set the default to "Low".
This field has an appearance of "minimal".
begin repeatequip_assessEquipment Assessment
select_one equipmentpark_equip<b>Equipment</b>
select_one pass_failpass_failPass/Fail
select_multiple criteriaarea_publicFail Criteria
textfailure_reasonReason for Failure
select_one riskriskassessmentRisk
end repeat
Thanks.
JamesTedrick
Hi John,
Again, I am able to get this to work.  See the attached sample.  One thing to note is that he default must be the 'name' value of the choice, not the label.
