Query widget subtype field
1104
02-19-2018 06:11 AM
MuglaCbs1
Hi; i have a feature service;
it has subtype fields and related differend domains for each subtypes.
feature service fields:
field x = (subtype)
value: "1" Label "a"
value: "2" Label "b"
value: "3" Label "c"
field y
if select subtype 1 domain: "k"
if select subtype 2 domain: "l"
if select subtype 3 domain: "m"
Normaly with  edit widget; i can add values by selecting a value from "field x"
then i can choose a value from "field y" by related domain values
But in query widget;
i am trying to choose a point by selecting a value from "field x" and by choosing "Values filtered by previous expressions" a value from "field y"
But after choosing  a value from "field x", in "field y" populates all domain values "k-l-m"
SQL EXPRESSİON
(field x = 2) AND (Field y= 'k')
How to make
SQL EXPRESSİON
(field x = b) AND (Field y= 'k')
i want to choose from "field x" then "field y" related domain records only.
in query widget guide page there is a note;
Caution:
To display the description for coded values when Values filtered by previous expressions or Values filtered by all other expressions is selected, the service must support the capability of query by statistics.
In my service;
Advanced Query Capabilities:
      Supports Statistics: true
      Supports OrderBy: true
      Supports Distinct: true
      Supports Pagination: true
      Supports TrueCurve: false
RobertScheitlin__GISP
What version of ArcGIS server are you working with?
MuglaCbs1
i am working with ArcgisServer 10.4
