How Do I turn OFF "Invalid Field Name" and "database Field Name" tag in Excel
3021
02-17-2018 04:38 AM
AaronColbran1
When using the "label" column in a Survey123 excel X-form the "Invalid Field Name" dialog box pops up EVERY time an edit is made to the label field. The error states you need unique values and no spaces, none of which are true for a label field.
This causes significant downtime with any survey editing as the subsequent dialog box defaults to no, and not yes like it used to.  The error should be removed from S123.
The second issue are the yellow help boxes that get in the way of ANY editing of the fields of interest. They show the same misinformation that the Invalid Field Name dialog box does.
The only time either of these messages are relevant is in the 'name' column. Even there they are not needed as the generation process highlights the errors.
Please advise how to turn these "functionalities" off.
Please advise if these issues can be scheduled for removal in the next build?
JohnathanHasthorpe
Hi Aaron
This is the result of a data validation rule that is applied to the name field (not the note field). It looks like you may have done some copy and pasting in the form and this shifted to a different column,
To disable the error message go to Data=>Data tools=>click the data validation button
Then un-tick the the show error alert message box below
and click OK.
The error message will no longer display.
Cheers
John
JohnathanHasthorpe
Hi Aaron
and click OK.
Cheers
John
