Updating all attribute data in Feature Layer using ArcObjects
2701
02-17-2018 04:31 AM
ChristianDebono
I have a layer with over 250,000+ features, and I want to update all the attribute data using ArcObjects and C#. I have written the code below and it takes around 3 hours to perform the update. Can you suggest whether the code below is efficient enough and any suggestion regarding the delta tables please?
 public void updateWithCursor(IWorkspace workspace, IFeatureClass featureClass, List<Update> updateList)
            using (ComReleaser comReleaser = new ComReleaser())
                IWorkspaceEdit workspaceEdit = (IWorkspaceEdit)workspace;
                // Start an edit session
                workspaceEdit.StartEditing(false);
                // Start an edit operation
                workspaceEdit.StartEditOperation();
                // Use IFeatureClass.Search to create a search cursor.
                IFeatureCursor searchCursor = featureClass.Search(null, false);
                comReleaser.ManageLifetime(searchCursor);
                // Find the positions of the fields used to get and set values.
                int idIndex = featureClass.FindField("ID");
                int serialIndex = featureClass.FindField("SERIAL");
                int cityIndex = featureClass.FindField("CITY");
                int updateDateIndex = featureClass.FindField("UPDATEDATE");
                int counter = 0;
                IFeature feature = null;
                while ((feature = searchCursor.NextFeature()) != null)
                    string searchValue = feature.get_Value(idIndex).ToString();
                    if (searchValue != "")
                        Update upd = updateList.SingleOrDefault(x => x.id == searchValue);
                        if (upd != null)
                            feature.set_Value(serialIndex , upd.serialNo);
                            feature.set_Value(cityIndex , upd.city);
                            feature.set_Value(updateDateIndex, DateTime.Now);
                            feature.Store();
                        Console.WriteLine(counter++);
                workspaceEdit.StopEditOperation();
                // Stop the edit session. The saveEdits parameter indicates the edit session
                // will be committed.
                workspaceEdit.StopEditing(true);
Tags (1)
ModyBuchbinder
Hi
Use UpadteCursor and do not use StartEditing (you are not doing undo or redo).
Check this: http://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#521a263d-dcee-47b9-b41b-33ef3fb4c558...
Have Fun
Mody
ChristianDebono
My data is versioned, If I don't use StartEditing; an exception is thrown 'Objects in this class cannot be updated outside an edit session'
GKmieliauskas
Have you tried ITransactions interface? It works without StartEditing fine on big quantities data with file or personal geodatabases. I have not tried it on SDE
