How to close a ShapefileFeatureTable instance?
1556
02-16-2018 09:20 AM
HenryHan
Hello there.
I am using ArcGIS Runtime SDK for .NET(WPF) to develop a software which can open and read the shapefile.
So, the first step is using "ShapefileFeatureTable.OpenAsync" function to open it.
But I can not find any "Close() or Dispose()" method to close it after using the shapefile. Which makes other software cannot open it anymore unless I close my program.
Here is the web document I use for reference:
ShapefileFeatureTable Class
Is there anyone who met the same problem?
How to solve this?
Thanks in advance.
Tags (1)
JenniferNery
Thanks for your feedback. From within runtime, you can use the same file path to create multiple instances of ShapefileFeatureTable without lock issue. I have also tried multiple instances of this app and the tables are created and loaded without a problem.
However, I have not tried another software that fails to open the shape file because it's in use. Is the other software attempting to edit simultaneously with your runtime app? I can put in an enhancement to include Close method but we'd also appreciate more information.
Thank you.
HenryHan
Hi Jennifer
Thanks for the reply!
Yes. What I did is using another software (GlobalMapper) to open the shape file.
I am developing a program to check the shapefile.
After opening my program, loading the shapefile, and finishing all of the necessary works, I hope I can "Close" the file instance without close my program.
Then I can open the shapefile in other software. Like: Global Mapper
And this will cause the file opening problem.
Thank you for your help!
