Hello -
Just checking that this is a valid workflow using survey123
Problem - User needed to make a change in the survey (change answer required to not required)
When attempting to republish this error message appears. (Survey name redacted)
Possible Solution
Create a new survey and publish it.
However we need the old results from the first survey
If the schema is the same in theory could we append the data to the new Feature Service that is created when we publish the new survey?
-Would these appeneded results appear in the analysis tab in Survey123 - granted the Edit dates/ submitted dates would be different
Are there other potential pitfalls that could happen
If there are any other ideas or workflows that I have not thought of feel free to add in comments
Cheers
