How to merge/dissolve 3D polygons with common ID to create a singlepart building?
1603
02-16-2018 07:22 AM
AleksanderStysiak
Hi!
I have a 3D city model made out of individual polygons. Polygons forming one building have a common ID (also attr like Type: Wall, Roof). I need to combine/merge/aggregate together shapes beloning to each building, so when I select a building it markes an entire entity and not just one of the polygons. The output should be a shapefile or multipatch.
I tried using dissolve but it fails each time. I want to use data later in Pro and CityEngine.
Anyone has an idea how to do that kind of ID-based multipart to singlepart merge?
I attached also sample data
Thanks!
DanPatterson_Retired
It worked form me (did it in PRO, but that shouldn't matter)
I just dissolved on the ID field.
You just get the outline from the multipart... check the options I used
AleksanderStysiak
Hey Dan
Thanks for the input and your time.
I tried this approach earlier but with no result. I tried again with those settings you propose but it also fails.
There is not much that can be wrong with this so I cant figure out the issue.
Nevertheless, I fixed it with FME
LauraGockert
Hey Aleksander,
I have the same problem. How exactly did you fix it with FME?
Thanks for your help!
