Start a widget on map load
1709
02-15-2018 04:48 AM
BrettKruger
Hi Guys
Could someone please assist me, I used WAB v2.1 - 2.4 and my widgets was working fine. When the map started, the code inside the widget run. This was as simple as adding to the config file: "openAtStart": true
For some reason in v2.7 this is not the case and it seems the config files has changed.
Could someone please guide me on which config and what do I need to change in this version so that my widget will run when the map loads?
Thanks in advance.
Brett
Adri2cPérez_Beneito
Hi!
An example using 2.7. (config.json)
 "uri": "widgets/Legend/Widget",
 "version": "2.7",
 "id": "widgets_Legend_Widget_18",
 "name": "Legend",
"index": 2,
"openAtStart": true
Cheers
