DAML Adding Tool to existing Ribbon
5105
7
02-14-2018 08:16 AM
BrianBulla
Honored Contributor
I use the following to create a custom Ribbon.  Initially it has 3 groups as well as places a couple of tools (the Streetview tools) in the proper place:
<modules>
    <insertModule id="StreetView_ArcPro_Module" className="Module1" autoLoad="false" caption="Module1">
      <tabGroups>
        <!--The new Tab Group is created here-->
        <tabGroup caption="DSM Custom Tools" id="DSM_Tools_tabGroup">
          <color A="255" R="238" G="170" B="90" />
          <borderColor A="0" R="251" G="226" B="195" />
        </tabGroup>
      </tabGroups>
      <!-- uncomment to have the control hosted on a separate tab-->
      <tabs>
        <tab id="Digitizing_Tools_tab" caption="Digitizing Tools" tabGroupID="DSM_Tools_tabGroup" keytip="T1">
          <group refID="Google_Streetview_group" />
          <group refID="Map_Tools_group" />
          <group refID="Editing_Tools_group" />
        </tab>
      </tabs>
      <groups>
        <!-- comment this out if you have no controls on the Addin tab to avoid
              an empty group-->
        <group id="Google_Streetview_group" caption="Google Street View" keytip="G1">
          <!-- host controls within groups -->
          <button refID="StreetView_ArcPro_Dockpane_ShowButton" size="large" />
          <tool refID="StreetView_ArcPro_StreetView_Tool" size="large" />
        </group>
        <group id="Map_Tools_group" caption="Map Tools" keytip="G1">
        </group>
        <group id="Editing_Tools_group" caption="Editing Tools" keytip="G3">
        </group>
      </groups>
      <controls>
        <!-- add your controls here -->
        <tool id="StreetView_ArcPro_StreetView_Tool" caption="Google Street View" className="StreetView_Tool" loadOnClick="true" smallImage="Images\Google-Earth-icon 16.png" largeImage="Images\Google-Earth-icon 32.png" condition="esri_mapping_mapPane" keytip="B1">
          <tooltip heading="Google Street View Tool">Click on map to show Google Street View location in side panel.<disabledText /></tooltip>
        </tool>
        <button id="StreetView_ArcPro_Dockpane_ShowButton" caption="Open Street View Pane" className="Dockpane_ShowButton" loadOnClick="true" smallImage="Images\open_in_new_window.png" largeImage="Images\open_in_new_window.png" keytip="B2">
          <tooltip heading="Show Side Panel">Click to open/activate Google Street View side panel.<disabledText /></tooltip>
        </button>
      </controls>
      <dockPanes>
        <dockPane id="StreetView_ArcPro_Dockpane" caption="Google Street View" className="DockpaneViewModel" dock="group" dockWith="esri_core_contentsDockPane">
          <content className="DockpaneView" />
        </dockPane>
      </dockPanes>
    </insertModule>
  </modules>
As I create more tools, I place them into the proper Group on the same ribbon, like below for the Attribute Update tool:
<modules>
    <insertModule id="AttributeUpdate_ArcPro_Module" className="Module1" autoLoad="false" caption="Module1">
      <controls>
        <button id="AttributeUpdate_ArcPro_AttributeUpdate_Button" caption="Update Multiple Attributes" className="AttributeUpdate_Button" loadOnClick="true" smallImage="Images\AttributeUpdate_16.png" largeImage="Images\AttributeUpdate_32.png">
          <tooltip heading="Atribute Update Tool">Updates multiple attributes from all of the selected features in the map.<disabledText /></tooltip>
        </button>
      </controls>
    </insertModule>
    <updateModule refID="StreetView_ArcPro_Module">
      <groups>
        <updateGroup refID="Editing_Tools_group">
          <insertButton refID="AttributeUpdate_ArcPro_AttributeUpdate_Button"></insertButton>
        </updateGroup>
      </groups>
    </updateModule>
For some reason, I cannot place this tool (Facility ID Tool) on the toolbar using this:
<modules>
    <insertModule id="FacilityID_ArcPro_Module" className="Module1" autoLoad="false" caption="Module1">
      <controls>
        <button id="FacilityID_ArcPro_FacilityID_Button" caption="Create Facility ID" className="FacilityID_Button" loadOnClick="true" smallImage="Images\ID.png" largeImage="Images\ID.png" keytip="btnFacID">
          <tooltip heading="Facility ID Tool">After selecting features, use this button to create new Facility IDs with selected features.<disabledText /></tooltip>
        </button>
      </controls>
    </insertModule>
      <groups>
        <updateGroup refID="Map_Tools_group">
          <insertButton refID="FacilityID_ArcPro_FacilityID_Button"></insertButton>
        </updateGroup>
      </groups>
    </updateModule>
  </modules>
I've looked at this a million times and don't see anything wrong with it.  Can anybody see where I am going wrong??
ThomasEmge
Brian,
make sure that you enforce a load order for your extensions. Please take a look at this thread https://community.esri.com/thread/208356-how-to-add-a-button-to-another-addins-group
- Thomas
ThomasEmge
Brian,
- Thomas
BrianBulla
Honored Contributor
Hi Thomas.   I was kind of wondering how things got loaded up, and if the order might be a problem, but it has always worked thus far.  I guess I was just getting lucky, and today my luck ran out!
Thanks for the tip!  That worked perfectly.
Wolf
by Esri Regular Contributor
Hi Brian,
 You can also find some documentation on DAML load dependencies in the ArcGIS Pro SDK Wiki here: https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-Advanced-Topics#control-order-of-loading-usi...
- Wolf
MarvisKisakye1
Brian Bulla, how were you able to use custom icons for your addin tools? When i attempt to use custom images that are not esri's defaults, the images don't show up on the addin.
GKmieliauskas
Hi Marvis,
Set property "Build Action" of your image to "AddInContent".
BrianBulla
Honored Contributor
Yes, you will need to:
1.  add the Image to your project (I normally use .PNG but I think other formats will work too)
2.  as Gintautas said, make the Build Action 'AddInContent'
3.  modify the Config.daml to reference the image from step #1.
MarvisKisakye1
This works perfectly. Thank you!!
