List of Compounding Months - Python
1187
5
02-14-2018 04:46 AM
Business_IntelligenceSoftware
I'm not sure if compounding is the right word for what I'm asking; but, is it possible to make a python list of compounding/cumulative months? For example, [Jan, Jan+Feb, Jan+Feb+Mar]. I want to use this to help me show customer growth from month to month. I've looked online, but can't find any examples of this. Is it possible?
DanPatterson_Retired
A cumulative sum... the easiest is to use the builtin cumsum from numpy... a demonstrate using 1 through 12 assuming... numpy is builtin and just needs to be imported in your scripts.
import numpy as np
a = np.arange(1,13)
c_sum = np.cumsum(a)
c_sum
array([ 1,  3,  6, 10, 15, 21, 28, 36, 45, 55, 66, 78], dtype=int32)
Another example
 b = np.random.randint(1, 4, size=12)
b
array([3, 3, 1, 3, 3, 2, 2, 2, 2, 3, 1, 2])
np.cumsum(b)
array([ 3,  6,  7, 10, 13, 15, 17, 19, 21, 24, 25, 27], dtype=int32)
or as a simple function
sum = 0
for i in b:
    print(sum)
    sum += i
print(sum)
7
10
13
15
17
19
21
24
25
27
Thanks for responding so quickly. I tried your first example, but the IDE says that "array" and "int32" are not defined. Also is line 7 from example 1 only supposed to say "c_sum"?
That was a demonstration of what to do
  • import numpy as np  #  this is the python module that is needed
  • variable 'a' ... I made an array of data to demonstrate the processes
  • variable 'c'  .... I used one of the built-in function of numpy ... specifically 'cumsum' to get the result.  In python, when I imported numpy as np... np is now the numpy module with a 'nickname'.  I use 'module.function' to get a result.  In other words.... use the numpy cumulative sum function to get a cumulative sum  of variable 'a'.....therefore   c = np.cumsum(a)
  • the second example... was just another example...
  • the third example... is just an example of how to do cumulative sums the old-school way
That pretty well 'sums' it up from start to finish... cumulatively
JoshuaBixby
MVP Esteemed Contributor
I am not sure which version of Python you are using (2.x or 3.x), but accumulate was introduced in Python 3.2 if you are using Python 3:
>>> from itertools import accumulate
>>> l = [3, 3, 1, 3, 3, 2, 2, 2, 2, 3, 1, 2]
>>> list(accumulate(l))
[3, 6, 7, 10, 13, 15, 17, 19, 21, 24, 25, 27]
Good point... but If you are still using ArcMap (python 2.7)  The numpy version is available for both 2.7 and 3.6
