Is possible to publish a survey using a command line or python script to Portal for ArcGIS/AGOL ?
3147
9
02-13-2018 01:24 PM
Cristian_Galindo
I have the folder for a survey created with Survey 123 Connect, I am able to publish it using Survey 123 Connect, but I was wondering if it is possible to publish it using a command line utility, a powershell script or a python script.
Any hints, ideas?
JamesTedrick
Esri Esteemed Contributor
Hi Cristian,
We don't formally support command-line publishing of forms at this time; however, the process of publishing the form is discoverable via the AppStudio Survey123 Connect (Template).  Aside from the creation of the form item, a relationship between the form and the submitting feature service also exists.  You may also want to look at Updating the media folder of a Survey123 Form item, which is one of the most common use cases for automating the publishing process.
JamesTedrick
Hi Cristian,
Cristian_Galindo
looking at that code, it is bit tricky trying to implement it as a powershell script.
JamesTedrick
Hi Cristian,
The trickier parts relate to the creation of the feature service based on the form XML.  If you already have a feature service, it is more a matter of zipping up the form files and posting into ArcGIS Online.  Invoke-RestMethod looks to be the best method in powershell, as it automates the response handling.
Cristian_Galindo
first, thanks for your answer.
Just to be clear, should I install the AppStudio, then download/open the "Survey123 connect template"in order to check the process?
Cristian_Galindo
How do I get AppStudio??? I just get an ArcGIS Developer Premium Annual Subscription, I tough it will be included there....I can't find it
JamesTedrick
Hi Cristian,
Yes, AppStudio Desktop should be available with the Developer Subscription.  clesueur-esristaff‌ - Can you help identify where to get AppStudio?
Cristian_Galindo
Thanks!!, I was digging in the ESRI network and find it. rigth now i am installing it
MaazaMekuria
Is there any update after two years on the ability to publish surveys on command line or batch?
ChrisWoodward
