Resolving Error 1406 when installing Portal for ArcGIS
4400
02-09-2018 12:56 PM
MichaelSchoelen
We are attempting to install Portal for ArcGIS, and we encountered:
Error 1406. Could not write value Installer to key \Software\ESRI\Portal for ArcGIS.  Verify that you have sufficient Access to that key, or contact your support personnel.
I found an old posting from Esri about this issue related to installing an old version of ArcCatalog, and it suggests that it can be resolved by disabling our antivirus software during the installation--and we would rather not attempt that.
Has anyone else encountered this error? And what is the solution. I'm not entirely sure what folder I need access to.
Access
 We are using Chef, but the same error comes up when manually installing, as well.
RandallWilliams
That's under HKLM/Software/Esri...some organizations prevent write to HKLM and allow HKCU.
RandallWilliams
MichaelSchoelen
Accessing that folder through `REGEDIT` in command prompt, I see that I can add permissions for myself to write to that folder.
Should I be giving permissions to the arcgis system account to write to HKLM?
