Multiple features (e.g., sampling events) represented by one point?
1623
02-08-2018 09:23 PM
deleted-user-LNABNwA5CZcD
I've looked probably too hard at this point but am sure there must be an easy way to do this.
I do a lot of sampling. Our sampling locations are the same. What I would like to display in ArcGIS Online (be it a map or Web App) is a single point where you can click, and in the pop-up is a table of past results for the site.
It's almost like collector, but I want to see the history displayed, too. Let me know if you have any questions. Thanks!
KellyGerrow
Esri Alum
Hi Sam,
You can approach this one of two ways.
1.  create a field for each sample date so the data is stored as multiple attributes for a given dataset.
2. If you have multiple fields that need to added for each dataset, try using related records to record the sample and relate the tables to a single location.
Create Relationship Class—Data Management toolbox | ArcGIS Desktop
Pop-ups can be constructed to display the values in related tables from one location:
Configure pop-ups—ArcGIS Online Help | ArcGIS
-Kelly
Kelly, I'd really rather not create additional fields with each sampling. I'd like to be able to simply fill out a form for each sampling site/event and have it populate a table like this:
SiteDateNitrogen (mg/L)Phosphorous (mg/L)
1T1/1/18
0.2
0.1
2T1/1/180.40.35
1T2/1/180.150.4
2T2/1/180.30.7
1T3/1/180.61.0
2T3/1/181.11.5
The map would have a single point for 1T and for 2T. Upon clicking, a pop-up would show something like the above table or perhaps even a chart of change over time.
My ideal is to manage data in a Google Spreadsheet, then have the sampling events at least listed (and perhaps charted or statistically summarized) in a single pop-up (rather than clicking through the pop-up windows for each event/feature).
One point, one pop-up compiling multiple features with a common site name.
Let me know if there are any other questions. I feel like this must exist somewhere somehow and I'm missing it.
I thought of another way to say it after playing with clustering, which I figured might be a pathway to a solution but does not appear to be (yet). Let's say this was achievable through clustering. When clicking on a cluster point that might have clustered three points, I want the pop-up to list out (ideally in a table and/or chart, but I'm open to other options) all the fields for all the features (same Site, multiple sampling events). I might also want summary info (e.g., average), too, but we'll really want to see how data changes over time.
KellyGerrow
Esri Alum
Thanks Sam,
Check out using related records (Option 2 above). This should accomplish what you are looking to do.
This web map should have a similar data structure to what you have described:
http://arcg.is/1zy1mz
Try clicking at the B13-9193 station for an item with corresponding related records
-Kelly
