Limit Inbox results in Survey 123
1327
02-08-2018 08:34 AM
IanBarwell
Is there a way to limit inbox results in Survey 123?  Ideally this would be by date -  i.e. only surveys submitted from the current day would show when refreshing the inbox.  Currently, when refreshing a specific survey, it pulls thousands of submitted surveys and takes a very, very long time to get the data.
BrandonArmstrong
Hi Eric,
I believe that you are looking to use the Inbox Filter as outlined in the documentation linked below...
Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS
As you stated that you have thousands of surveys, please keep the following in mind after applying your filter...
Known issues—Survey123 for ArcGIS | ArcGIS
Brandon
