Hi Everybody,
I`ve a new question regarding a new Add-In I`m writing. It`s still for ArcGIS Pro 1.4 and SDK version 1.3.0.5861 because it extents another system on that state. Basically it monitors a local GPS device via serial port and shows the data in different ways. Everything works as desired at the moment but I`m experiencing the behaviour that my ArcGIS Pro buttons from time to time grey out /disable for a short moment.
I know this may have something to do that my UI-thread is blocked somehow but I can`t imagine the reason.
Because my Add-In has already some code in it I decided to attach the complete project as attachment. It will not run as stand-alone because it expects another add-in to be present but maybe the full code will be helpful.
Additionally I`ll try to explain what I`m doing in simplified pseudo code here:
protected GpsPanelViewModel()
_gpsReader = new GPSReader();
_gpsReader.RaiseGpsValuesReceivedEvent += HandleNewGPSValuesReceivedEvent;
private async void HandleNewGPSValuesReceivedEvent(object sender, GpsValueReceivedEventArgs e)
var disposable = await QueuedTask.Run(() =>
// Do something with received GPS-Data
// Add map point and update view model parameters for UI update
public void DoSomethingWhenGPSButtonIsClicked(object obj)
if (_gpsIsActive == false)
_gpsReader.StartReading();
else
_gpsReader.StopReading();
public class GPSReader
private Thread _readGpsThread;
private Thread _parseGpsThread;
private System.Threading.Timer _timerReader;
private System.Threading.Timer _timerParser;
private BlockingCollection<GpsRawData> _gpsDataBuffer;
public void StartReading()
_readGpsThread = new Thread(StartGpsReaderLoop);
_parseGpsThread = new Thread(StartGpsParserLoop);
_readGpsThread.Start();
_parseGpsThread.Start();
public void StopReading()
ClosePort();
_timerReader.Change(Timeout.Infinite, Timeout.Infinite);
_timerParser.Change(Timeout.Infinite, Timeout.Infinite);
_readGpsThread.Abort();
_parseGpsThread.Abort();
private void StartGpsReaderLoop()
_timerReader = new System.Threading.Timer((e) =>
GetData(); // GET data from GPS and store in _gpsDataBuffer
}, null, 0, 1000);
private void StartGpsParserLoop()
_timerParser = new System.Threading.Timer((e) =>
ParseData(); // Get raw data from _gpsDataBuffer and raise event when finished
}, null, 0, 500);
The main question for me is, where does the probem occur? Is it because I`m running two additional threads in my GPS-Reader?
Any help would be very appreciated.
Best regards
Richard
By default, buttons on the ribbon automatically become disabled whenever something is running on the main worker thread (the thread associated with QueuedTask.Run). Buttons can opt out of this by setting their DAML disableIfBusy attribute to false. However, if your task is using ArcObjects it should use QueuedTask and it should probably keep disableIfBusy = true. If your task isn't running ArcObjects (maybe you'll pulling something down from the web or using your own objects to do something), you might want to consider using a thread from the .NET thread pool (Task.Run) and disableIfBusy=false.
<button id="acme_ShowWiz" caption="Show Wizard" className="ShowWizardCMD" loadOnClick="true" disableIfBusy="false"
