Slice Label ReOrdering?
4080
02-05-2018 11:13 AM
AndrewHargreaves2
Hi
Is there a way to re-order the labels of a pie chart? I want to move those shown in the attached example.
DavidNyenhuis1
Hi Andrew Hargreaves‌,
In the Data tab, you can configure the "Sort By" property. You can sort your slices by the statistic (e.g., large to small) or by the category/slice field (e.g., alphabetically asc/desc). Your legend sorting is also controlled by this property. At this time there is not a way to apply a custom sort order.
MarcoConopio2
Hi @DavidNyenhuis1
Can I ask if there is now a way to apply custom sort order to pie charts in Dashboard?
Can AGOL Assistant be used to apply custom order?
Thank you!
