adding excel with colored cells into layout
2311
8
02-05-2018 07:55 AM
GailMorrison2
When I open excel, add information into the cell, color (fill the cell with color), then insert the Excel spreadsheet into an MXD as an object or copy/paste, the XLS colored cells look great. When I export the map, the color goes away - as though they were never colored / filled.  How do I get the colored cells to maintain their color when I export the map to a PDF?
AdrianWelsh
MVP Honored Contributor
Gail, what about when you export to something else, like a jpg. Does the color still go away? I supposed you could just make that excel table into a graphic and export it that way (and lose the excel functionality but it may be worth it).
GailMorrison2
Hi Adrian,
I tried this. The cell fill color drops out. JPG, PDF … A few of my coworkers can export just fine. Copy / paste an xls or xlsx or csv into an MXD / layout. A few of us cannot. Any suggestions?
Once I get the xls issue worked out, I need to make the xls a dynamic table. I have a SOP on this, tho.
Kind Regards,
Gail
Gail Morrison
Gail.Morrison@fema.dhs.gov<mailto:Gail.Morrison@fema.dhs.gov>
FEMA - GIS Specialist
Incident Complex – Puerto Rico
FEMA-4339-DR/FEMA-3391-EM
( 202) 709.0658 Mobile
AdrianWelsh
Gail,
That's odd that it works for some and not for others. What are the differences between yours and your coworkers setups? Same version of GIS? Same license for each user?
GailMorrison2
Yes to all your questions. It’s very frustrating!
Kind Regards,
Gail
Gail Morrison
GailMorrison2
Also, I used the exact same export settings as one of my coworkers.
Kind Regards,
Gail
Gail Morrison
AdrianWelsh
Then it must be related to a graphics setting on the individual PCs, I would think.
Or, what version of ArcMap are you running? Are you using an xls or an xlsx file (and what version of that - like 2016, etc.)?
Can the working PC export a map package and then have you try it on your non-working PC to see if there is a difference in the settings somewhere?
Do you have the original excel file closed when making the export?
There are some helpful hints in this article that might help (it's about charts but it's the same idea):
How To: Insert an Excel chart into ArcMap
GailMorrison2
I ended rebuilding the MXD. The original size was Architectural D. When I recreated the MXD at 8.5 x 11 … it exported just fine. It has to be the settings in how my ArcMap exports the files. Some sort of internal setting?
Kind Regards,
Gail
Gail Morrison
AdrianWelsh
MXDs are weird and sometimes, when used a ton and saved a ton, they start getting bloated. The best bet is to re-save an MXD as a new copy every so often. What you will see is that it will significantly reduce the file size and give you better performance (like you have seen). I imagine that if you were to use this newly created MXD and switch back to the original paper size you wanted, it should work like expected (I'd hope at least).
