Runtime equivalent of JavaScript Callout
1202
01-31-2018 11:34 AM
AnatBen_Israel
Is there a runtime equivalent of the JavaScript callout?
I have PictureMarker symbols in my scene that are not on the ground, but I want them to have a line that connects them to the ground so they have height but they don't float... (Attached a picture of the JS callout)
Couldn't find a way to do it.
I've tried to create a cylinder between the ground the the symbol's location, but it's not good enough.
The symbol, in my specific case, represents an observation system, and if the cylinder is at the same height as my symbol, it blocks the system's line of sight and viewshed.
LucasDanzinger
Esri Frequent Contributor
Currently any graphic in the SceneView will be used in the Line of Sight or Viewshed analysis. We are considering adding a way to exclude graphics. Once we have that, you should be able to add the cylinder with a text symbol.
