Inbox Filter by Date in Query Expression
8575
12
01-29-2018 12:57 PM
MarioFederis1
Is it possible for the inbox to show submitted forms only from the last 5 days? Perhaps through the inbox filter query expression which looks at a date field (example below).
My organization has over 3000 entries in survey123, and whenever a user refreshes their inbox, it takes an extremely long time to load.  They only need to edit the most recent submissions
JamesTedrick
Esri Esteemed Contributor
Hi Mario,
This type of query should be possible, though it currently takes a little debugging to get the syntax correct.  In the query expression language, there are the keywords CURRENT_TIMESTAMP and CURRENT_DATE (Standardized SQL functions in ArcGIS Online—ArcGIS Online Help | ArcGIS ).  These are used by ArcGIS Online's filter to create a date-bound query.  For the example of the last 5 days, the query is:
requestDate BETWEEN CURRENT_TIMESTAMP - 5 AND CURRENT_TIMESTAMP
JamesTedrick
Hi Mario,
MarioFederis1
Thanks James! It worked. I assumed it was possible but just didn't know what the calls were.
AprilChipman
I'm not having any luck with this expression, and I think it may be due to my field type. My field name is 'date' and it is a esriFieldTypeDate. Can I still filter the Inbox for the last 10 days?
If not, any suggestions on a workaround?
(I'm in Enterprise 10.6.1 and using Survey123 Connect 3.7.62)
JamesTedrick
Hi April,
I'll note that date is normally a reserved keyword - can you confirm the name of the field from the REST API?
edit_date between CURRENT_DATE - 10 AND CURRENT_DATE as a sample query works for me in ArcGIS Enterprise
AprilChipman
From what I understand, the field name is indeed "date"
AprilChipman
It worked!
Looking through my logs, I was trying to use 'CURRENT_TIMESTAMP' instead of 'CURRENT_DATE'.
date between CURRENT_DATE - 10 AND CURRENT_DATE    is the query that works.
ryanEvanczyk
I am trying to write a query so that the inbox shows only records from the current day. I have tried querying a date field - event_date=CURRENT_DATE which gives the code 400 invalid parameters. I read in the prepare to edit blog post that said you couldn't use a date field type with this query and it must be formatted yyyy-mm-dd. So I made a hidden type, then set it as a string, and in the calc column formatted the dateTime field above to be yyyy-mm-dd. Then set the query as event_date=CURRENT_DATE again and it doesn't throw the error, but no surveys show up. Not sure if I need to mess with the SQL standard or non-standard queries, or just set a range as one day?
Thanks!
JamesTedrick
Hi Ryan,
edit_date >= CURRENT_DATE should be used (remember, the time component of a date-time will cause equalities to fail)
ryanEvanczyk
I used event_date>=CURRENT_DATE and the inbox didn't pull any sent surveys. It is a dateTime type, with a now() default.
When I add a -1 it pulls the current day and the previous day - event_date>=CURRENT_DATE-1 and functions as it should.
I tried adding a -0 and that didn't give me an error, but still didn't pull any sent surveys. I also tried getting rid of the default and changing it to a date type.
We don't send that many surveys a day, so it's probably fine. Do I just need to add something else at the end? adjust for UTC time?
Thanks for your help!
