Web Form - Data field doesn't allow selection of a date withing the current month
1375
5
01-29-2018 10:00 AM
JAVIERVARA_SANZ
I was on a hard deadline and wasn't able to ask this question earlier.
I have a date field in my web form (created using Survey123 Connect) and wanted to add a constraint to make sure later days than current were not allowed. This didn't work, so I ended up removing it, although the issue persist. I found out later I was restricted from selecting any date withing the current month. My last option was to create a text field with a regex constraint that would ensure a correct entry.
Any advise in this regard will be highly appreciated.
JamesTedrick
Esri Esteemed Contributor
Hi Javier,
Can you share the XLS file of the form?
JAVIERVARA_SANZ
Adding to my previous comment. The issue is only happening in Internet Explorer. Any other browser (Chrome, Edge, Safari) works fine.
JAVIERVARA_SANZ
James.
I've been trying to replicate the issue, but it works now. I wonder if the latest version has anything to do with it.
Thank you and sorry for the inconvenience.
JamesTedrick
Hi Javier,
There was a bug with submitting dates in IE that was resolved- it sounds like you were affected by that issue.
JAVIERVARA_SANZ
Thanks James.
Much appreciated.
