setRenderer error getFieldsUsedInExpressions is not a function
8292
19
01-29-2018 06:55 AM
AbhinavSharma
Hey everyone, I am attempting to create a renderer where the user is able to select the field on which to render based off of. I need to use UniqueValueDefinition as my render which means that I cannot use RendererChooser class—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers. After selecting the field the chrome console shoots back the following error
Uncaught TypeError: a.getFieldsUsedInExpressions is not a function
My feature layer is created like so:
var landusePolygonLayer = new FeatureLayer("https://services7.arcgis.com"),
            mode: FeatureLayer.MODE_ONDEMAND,
            outFields: ["*"]
I then call getData() after the user chooses the field ( which sets currField to that field which is used in the code below.
function getData(){
            classBreaks("#ffffcc", "#006837");
          function classBreaks(c1, c2) {
            var classDef = new UniqueValueDefinition();
            //define ColorRamp
            var colorRamp = new AlgorithmicColorRamp();
            colorRamp.fromColor = new Color.fromHex(c1);
            colorRamp.toColor = new Color.fromHex(c2);
            colorRamp.algorithm = "hsv"; // options are:  "cie-lab", "hsv", "lab-lch"
            //var classField = this.get("value")
            console.log("This.get(value)", currField);//confirm the field is correct in console
            classDef.attributeField= currField;//set def field to the user selected field
            classDef.type = "classBreaksDef";
            classDef.baseSymbol = new SimpleFillSymbol("solid", null, null);
            classDef.ColorRamp = colorRamp;
            //var params = new GenerateRendererParameters();
            //params.classificationDefinition = classDef;
            console.log("here")
            this.map.getLayer("canada_Risk").setRenderer(classDef);
            console.log("here2")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
var currField
define(
  ['dojo/_base/declare',
  "dijit/_WidgetsInTemplateMixin",
  'jimu/BaseWidget',
  "esri/toolbars/draw",
  "esri/toolbars/edit",
  "esri/graphic",
  "esri/request",
  "esri/config",
  "esri/Color",
  "esri/renderers/Renderer",
  "esri/tasks/ClassBreaksDefinition",
  "esri/tasks/UniqueValueDefinition",
  "esri/tasks/ColorRamp",
  "esri/tasks/AlgorithmicColorRamp",
  "esri/tasks/GenerateRendererParameters",
  "esri/tasks/GenerateRendererTask",
  "esri/layers/LayerDrawingOptions",
  "esri/layers/FeatureLayer",
  "esri/layers/Field",
  "esri/symbols/SimpleMarkerSymbol",
  "esri/symbols/SimpleLineSymbol",
  "esri/symbols/SimpleFillSymbol",
  "esri/dijit/editing/TemplatePicker",
  "esri/dijit/editing/Editor",
  "dojo/_base/array",
  "dojo/_base/event",
  "dojo/_base/lang",
  "dojo/parser",
  "dijit/registry",
  "dojo/data/ItemFileReadStore",
  "dojox/grid/DataGrid",
  "dijit/form/FilteringSelect",
  "dijit/form/Select",
  "dojo/on",
  "dojo/data/ObjectStore",
  "dojo/store/Memory",
  "dojo/domReady!"],
  function(declare,_WidgetsInTemplateMixin, BaseWidget, Draw, Edit, Graphic, esriRequest, esriConfig, Color,Renderer,
    ClassBreaksDefinition, UniqueValueDefinition, ColorRamp, AlgorithmicColorRamp,
    GenerateRendererParameters, GenerateRendererTask, LayerDrawingOptions,
    FeatureLayer,Field,
    SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
    TemplatePicker,Editor,
    arrayUtils, event, lang, parser, registry, ItemFileReadStore, DataGrid, FilteringSelect,Select, On,ObjectStore, Memory) {‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RobertScheitlin__GISP
Abhinav,
  So attached is a version of your widget using standard widget coding practices and it has been test, and works properly.
Abhinav,
   Based on the code you posted I would say this is your issue:
          function getData(){
            lang.hitch(this, classBreaks("#ffffcc", "#006837"));
You have a scope issue.
AbhinavSharma
Hi Robert, I ended up just removing that function entirely and hard coding the colours into my colorRamp. and calling classBreaks() as soon as a new field has been chosen and the error stays the same.
Abhinav,
   Can you provide more of your code?
AbhinavSharma
I will post the entire section of code:
var currField
define(
  'jimu/BaseWidget',
  "esri/graphic",
  "esri/request",
  "esri/config",
  "esri/Color",
  "dojo/_base/array",
  "dojo/_base/event",
  "dojo/_base/lang",
  "dojo/parser",
  "dijit/registry",
  "dojo/on",
  "dojo/domReady!"],
    FeatureLayer,Field,
      //To create a widget, you need to derive from BaseWidget.
      return declare([BaseWidget,_WidgetsInTemplateMixin], {
        // DemoWidget code goes here
        //please note that this property is be set by the framework when widget is loaded.
        //templateString: template,
        baseClass: 'jimu-widget-ROP',
        postCreate: function() {
          this.inherited(arguments);
          console.log('postCreate');
        startup: function() {
          ///INICIO/////
          parser.parse();
          // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/3/jshelp/ags_proxy.html
          esriConfig.defaults.io.proxyUrl = "/proxy/";
          map= this.map;
          map.on("layers-add-result", initEditing);
          var landusePolygonLayer = new FeatureLayer("https://services7.arcgis.cYy", {
            outFields: ["*"]
          console.log("LayerInfo", landusePolygonLayer)
          map.addLayers([landusePolygonLayer]);
          //fieldInfo
          var canadaFields = esriRequest({
            url:"https://services7.arcgis.com//0",
            content:{
              f: "json"
            callbackParamName : "callback"
          console.log("fields", canadaFields)
          var fieldNames, fieldStore;
          canadaFields.then(function(resp){
            fieldNames = { identifier : "id", label: "label", items: []};
            //console.log("fields", fieldNames)
            arrayUtils.forEach(resp.fields,function(f){
              fieldNames.items.push({"id": f.name, "label": f.name});
              // console.log("f_name", f)
              //this.sourceLayerFieldSelect.set("value", f.name)
              //console.log("fieldnamesForStore", fieldNames.items)
            var data = fieldNames;
            //console.log("dvfdata", data.items)
            var store = new Memory({
              data: data.items
            var os = new ObjectStore({objectStore: store});
            //console.log("dsds",os)
            var s = new Select({
              store: os
            }, "sourceLayerFieldSelect");
            s.startup();
            //  this.sourceLayerFieldSelect.store(os);
            //console.log("dsddssdsd",s)
            s.on("change", function(){
              //lang.hitch(this, this.get("value"));
              console.log("my value: ", this.get("value"))
              currField = this.get("value");
              classBreaks(currField)
          }, function(err){
            console.log("failed to get field names: ", err);
          function classBreaks(field) {
            //define ColorRamp
            colorRamp.fromColor = new Color.fromHex("#ffffcc");
            colorRamp.toColor = new Color.fromHex("#006837");
            console.log("This.get(value)", field);//confirm the field is correct in console
            classDef.attributeField= field;//set def field to the user selected field
            //console.log("here")
            console.log("riskCanada",this.map.getLayer("canada_Risk"))
            //var generateRenderer = new GenerateRendererTask("https://services7.arcgis.com/0");
            //generateRenderer.execute(params, applyRenderer, errorHandler);
AbhinavSharma
I think I might know what my problem is, I am using setRenderer for a definition and not an actual renderer. I have to change my code so that it uses an actual renderer. Do you have any idea if there is a way for me to just use myUniqueValueDefinition?
Abhinav,
   Here is your code with a lot of corrections. I have changed it to use standard WAB/dojo widget coding practices:
define([
  'jimu/BaseWidget',
  "esri/request",
  "dojo/_base/array",
  "esri/Color",
  "esri/renderers/UniqueValueRenderer",
  "dojo/_base/lang",
  "dojo/on",
  function(declare, _WidgetsInTemplateMixin, BaseWidget,
    esriRequest, arrayUtils, Color,
    UniqueValueRenderer, AlgorithmicColorRamp,
    FeatureLayer, SimpleFillSymbol,
    lang, FilteringSelect, Select, On, ObjectStore, Memory,
    GenerateRendererParameters, GenerateRendererTask) {
      return declare([BaseWidget, _WidgetsInTemplateMixin], {
        currField: null,
          this.map.on("layers-add-result", initEditing);
            outFields: ["*"]
          this.map.addLayers([landusePolygonLayer]);
          //fieldInfo
            content:{
              f: "json"
              data: data.items
              store: os
            s.startup();
            s.on("change", lang.hitch(this, function(){
              this.currField = this.get("value");
              lang.hitch(this, this.classBreaks(this.currField));
          }, function(err){
        classBreaks: function(field){
          var generateRenderer = new GenerateRendererTask("https://services7.arcgis.cYy");
          //define ColorRamp
          classDef.attributeField= field; //set def field to the user selected field
          generateRenderer.execute(params, lang.hitch(this, function(evt){
            this.map.getLayer("canada_Risk").setRenderer(evt.renderer);
          }), errorHandler);
AbhinavSharma
I was not able to apply all the cosmetic changes to the code due to a few blocks of code that i did not paste here breaking on me after making the changes. But i did add the bottom portion of your code (without the errorhandler) and now I do not get any errors in the chrome console but the layers do not render based off of the selected field.
edit1:
I got the error handler working and the error is
Something broke, error:  Error
    at Object.k.load (init.js:1007)
    at init.js:87
    at c (init.js:103)
    at d (init.js:103)
    at b.Deferred.resolve.callback (init.js:105)
    at c (init.js:104)
    at d (init.js:103)
    at init.js:92
    at h (init.js:107)
Widget.js?wab_dv=2.7:168 error:  {"code":400,"details":["Classification has missing 'classificationField' value."],"log":false,"httpCode":400,"_ssl":true}
Abhinav,
AbhinavSharma
After adding my layer urls to the widget and loading the widget onto my webapp the widget does not work. it does not give me any errors it just does not render and then when I move the map a little my layer does not load. I have attached a screenshot of the symbols as shown in the chrome console.
