Definition Query help? What query expression would I use for subsetting data to Burglaries occurring in December 2016?
1229
01-27-2018 12:45 PM
__17
I put this expression into the Definition Query, but it says that the SQL statement is invalid: "Type" = 'BURGLARY' AND "Date" BETWEEN date '2016-12-01 00:00:00' AND date '2016-12-31 00:00:00'
What could be incorrect with this query expression?
Thanks!
DanPatterson_Retired
Des...Tips...
  • do the burglary query first... if it works
  • do the date query second
    • If the date query doesn't work with between, try greater than your first date, that will check the date portion
  • if they both work, then put the subqueries in round brackets with the 'and' between
Sorry, but no date data to check with, but hopefully breaking it down will isolate your problem
__17
Okay thanks. It finally worked! I edited the query expression. I changed it to:
"Type" = 'BURGLARY' AND "Date" >= date '2016-12-01 00:00:00' AND "Date" <= date '2016-12-31 00:00:00'
However, I still get confused between the 'AND' and 'OR' operators. I hope I am using the correct operator for finding the burglaries occurring in December 2016.
__17
Nevermind, I checked. I did it correctly. I checked the attribute table. Thanks!
