Extract points above a certain height and within a buffer
1563
01-24-2018 01:59 AM
GregoryMcMahon1
I want to extract points from a feature class that fall within a buffer but are also above a certain height. What is the quickest method to do this?? I.E Points 50m abovesea level and are within 10km of the coast line (buffered)
Cheers
DanPatterson_Retired
Select by attribute on the points layer to get the points that meet the height requirement.  I assume that the points are a Points.Z file or you can use the Field Calculator to calculate geometry for the Z values.
Select by Location to get the points within the buffer layer. using a select from selected option
