How to dynamically add items into python addin Combobox from another addin combobox.
2140
01-23-2018 09:58 AM
SurendranNeelakantan
I have two combo boxes. I am trying to add items dynamically into the second combobox from the first combobox's "onSelChange(self, selection)" event.
due to some reason this is not working.
here is my sample code:
import arcpy
import pythonaddins
class ComboBoxClass1(object):
    def __init__(self):
        self.items = []
        self.editable = True
        self.enabled = True
        self.dropdownWidth = 'WWWWWW'
        self.width = 'WWWWWW'
    def onSelChange(self, selection):
        pass
    def onEditChange(self, text):
        pass
    def onFocus(self, focused):
        self.refresh()
        pass
    def onEnter(self):
        pass
    def refresh(self):
        self.refresh()
        pass
class ComboBoxClass2(object):
    def __init__(self):
        self.items = ["Location1","Location2","Location3"]
        self.enabled = True
        self.dropdownWidth = 'WWWWWWW'
        self.width = 'WWWWWWW'
        self.cb1= ComboBoxClass1()
        self.cb1.items.append(selection)
        self.cb1.refresh()
        pass
      # When the combo box has focus, update the combo box with the list of layer names.
      pass
    def onEnter(self):
        pass
    def refresh(self):
        self.refresh()
        pass‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
FreddieGibson
Honored Contributor
Hi Surendran Neelakantan‌,
As per our phone conversation earlier, we implemented the following to resolve this issue.
import arcpy
import pythonaddins
class cbxClass1(object):
    """Implementation for ComboBoxExample_addin.cbx1 (ComboBox)"""
    def __init__(self):
        self.items = [chr(n) * 3 for n in range(65, 65+3)] # [AAA, BBB, CCC]
        self.enabled = True
        cbxClass1._hook = self
        cbxClass2._hook.items.extend([selection])
class cbxClass2(object):
    """Implementation for ComboBoxExample_addin.cbx2 (ComboBox)"""
    def __init__(self):
        self.items = [chr(n) * 4 for n in range(90, 90 - 3, -1)] # [ZZZ, XXX, YYY]
        self.enabled = True
        cbxClass2._hook = self
        cbxClass1._hook.items.extend([selection])
As I stated on our call, there will be more than way to accomplish this. I will ensure that this approach is documentation on a public facing knowledge article. I will also pass this information along to the necessary parties to determine how we can better explain this workflow within our documentation. Please let me know if you have any problems with this.
Freddie G.
FreddieGibson
Honored Contributor
import arcpy
import pythonaddins
    def __init__(self):
        self.enabled = True
    def __init__(self):
        self.enabled = True
Freddie G.
Freddie,
This works !   Thank you  for the solution. I am excited  to know other options to accomplish the same goal.
Thank you
