Working with Enterprise Geodatabase (SDE) data in R using the R-ArcGIS Bridge
3531
01-22-2018 03:27 PM
SimonAllard2
Is it possible to read data from the enterprise geodatabase directly into R and write back to the enterprise geodatabase using the R-ArcGIS bridge?
Cheers,
Simon
ShaunWalbridge
Hello Simon,
To access data stored in an enterprise geodatabase, you have a couple of options: if it's just one layer you're working with, you can save a .lyr file, and work with that directly as a filepath. Otherwise, you can reference tables relative to their SDE connection file, see this answer for more details.
Cheers,
Shaun
SimonAllard2
Thanks for the answer Shaun, I know know how to read from the .lyr file or a direct connection to enterprise geodatabase.
What about writing back to SDE using R, is this currently possible?
Cheers,
Simon Allard
GIS Analyst
Bay of Plenty Regional Council Toi Moana
ShaunWalbridge
Simon,
Yes, you can use the same pattern to point at a layer file or direct connection when using arc.write to write the results out:
  arc.write('c:/path/to/my.sde/dbname.layername', results.df)
Where results.df is the data frame after you've made modifications.
Cheers,
Shaun
