When I type in (Asian/Total14popu) in the field calculator, I get results mostly being 0%,which is impossible. Am I calculating this correctly? I think not because I've been getting mostly 0% for my results except for some rows in the new field where I am calculating this from.
Python parser for the field calculator. ! ! around the field names
!Field1!/float(!Field2!) * 100.
You want to make sure you aren't doing integer division, hence convert one of the two fields (which are probably long/short integer) to floating point numbers. And if you want percentage, convert the ratio to a percentage by multiplying by 100
