Creating feature class failed with error 500 while publishing to ArcGIS Portal
2546
01-20-2018 03:57 AM
SrinivasSanthanam
JTedrick-esristaff
I am trying to publish a survey created by survey123 connect to our portal .
I am getting an error  Creating Feature Class Failed error 500.
I refered to this post earlier
Error code 500: Creating Feature Class Failed when publishing to Portal
It says that there is a maximum limit of 500 fields when publishing to portal. I have 300 odd fields. I have earlier published surveys with similar amount of fields. However I am not able to publish this survey.
Kindly provide some insight as this is a survey that needs to be published immediately.
With Regards
Srinivas
JohnathanHasthorpe
Hi Srinivas
Please can you please share the following:
1) The portal version and security configuration
2) The survey xls you are trying to publish
3) The debug logs from Connect (see: Troubleshoot—Survey123 for ArcGIS | ArcGIS )
I will then try to replicate your issue.
John
