I am trying to create a tally button for a survey. I am wanting a tally button on the survey that will populate a field. Example. Fuels measurments require a running tally while working. Instead of using a different app or device for a tally i was wondering if a general tally button could be added to a survey? Thanks
Hi Mathew
So you will be typing in fuel measurements as you go, e.g 10, 15, 10 and you want a running total e.g. 35.
Why not create a repeat with a decimal question in it? You could write in your values and then use the repeat aggregate function to sum up the total. This way you would save each fuel value to the feature service too.
Cheers
John
