Webappbuilder mobile popup issue with clustering enabled.
1164
5
01-17-2018 11:56 AM
Anish_Adhikari
I have clustering enabled for ArcGIS online web map for food establishments which I converted into a web application using online version of Webappbuilder. When multiple establishments are located in a single address point, clicking on symbology will give you this popup.
Webapp popup
When you click browse features It will show a popup with the ability to click left and right arrows to see popup info about next establishment in the cluster.
Browse Features
This is the way it should work.
When I view the app from a mobile device, If I click on the same cluster, I get this popup
Mobile popup cluster
This does not give me ability to view information about the facility. There is no browse features option. So essentially I cannot view information on a facility that is part of a cluster from a mobile device. Has anyone else encountered this issue?
Thank You
Anish_Adhikari
This has been now logged as a bug according to ESRI.
BUG-000111301: Viewing the clustering enabled Web Application on the mobile device doesn’t allows browsing or zooming to individual features clustered together.
RobertScheitlin__GISP
Anish,
   Have you tried to click on the mobile popups action menu button in the lower left hand corner?
Anish_Adhikari
Robert,
Yes, I clicked on the action menu button. The only options I get are pan to and add a marker. I am using iphone 6. This seems like a bug to me.It works normally on ipad.
Anish,
  OK this looks like a bug that needs to be reported to esri tech support then.
Anish_Adhikari
Robert,
Thank You. I will do that. I appreciate your help.
Anish_Adhikari
