Is there a way to automatically jump to another page in a survey based on a selection given to a multiple choice question?
1472
01-18-2018 11:37 AM
MatthewChatelain
I'm needing to basically open up another survey based on a given answer to a multiple choice question. I was hoping I could do this by going to the next page in a survey when selecting this option. Is this possible?
Also if its not can you hide groups only to appear when you select a certain option.
Thanks!
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Matthew,
It is possible to open a second survey from a survey by creating an application URL - see Integrate with other apps—Survey123 for ArcGIS | ArcGIS for more information in setting it up.  That being said, Survey123 isn't designed with this workflow in mind- the first survey will be in an unsubmitted state when you open the second survey.
Intra-form links are not supported within Survey123.
