Arcpy - ID generator using a Grid format
2072
9
01-17-2018 12:27 PM
SeanPhayakapong2
Would it be possible to create an ID generator with a grid system overlayed. For example, I have a point and I want the ID to be concatenated from the grid's row/column and a unique ID. For example if the point lands on grid the grid 30(column) and 23 (row) with it being the second point created in that box then the ID should look like this: 302302 being CCRRID. I am using 10.2.2 ArcMap.
DanPatterson_Retired
how many rows and columns?
how many times do you have to do this?
wouldn't joining the grid to the points suffice for the first part, then you could modify/calculate a supplemental key after?
What have you tried so far? This would take some coding and/or geoprocessing steps but what you have tried would go a long way
XanderBakker
Esri Esteemed Contributor
In addition to the questions that Dan asked, if you have 30 * 23 grid cells, you will have 690 possibilities. If the ID must be unique I guess you would have to use 3 positions for the ID. If the points already have information about the grid cells (row and column) you can concatenate and create the CCRRID. If you have polygons to represent the grid cells with info on row and column, you can create the CCRRID there and convert the centre points to a point featureclass. To clear up all the doubts, it would be best to attach the data too.
SeanPhayakapong2
This is primarily used for manholes, but here is the basic schematic that my employers want.
Example:
Example
The highlighted point is the tenth manhole (fc = 60) that was added in the 8th column (08) and the 22nd row (22) giving an ID by our standard of 600822010.
There will be about a 35x35 grid. For how many times would be as many times new data is added. So far I just coded an ID generator without any new relationship to the grid.
assigning row and columns to the 'fishnet' shouldn't be a problem and the number of the points if done in sequential order, isn't a problem either, if they are added out of order then that will require a manual entry of that value.  Concatenation isn't a problem either.
SeanPhayakapong2
Hi Dan,
Could you look over my python script? I am having trouble for the continuation of the sequential order for a particular tile in the grid portion. I don't know what I should have for my "ID" variable.
#Setting Parameters for tool
inputLayer = arcpy.GetParameter(0) #Input layer
idField = arcpy.GetParameter(1) #Facility ID Field
i = arcpy.GetParameter(2) # Feature Class Code
grid = r"R:\GISPROJECTS\Dept_WaterUtilities\Tools\OceansideToolbar\Shapefiles\Grids.shp"
arcpy.MakeFeatureLayer_management(grid, 'grid_lyr')
grid_lyr = 'grid_lyr'
field_names = arcpy.UpdateCursor(grid_lyr)
cursor = arcpy.UpdateCursor(inputLayer)
arcpy.AddMessage("Generating ID's...\n")
   for row in cursor:
      #Select by NULL attribute
      arcpy.SelectLayerByAttribute_management(inputLayer, 'NEW_SELECTION', '"FACILITYID" is NULL')
   for field in field_names:
   C = field.getValue('COL')
   R = field.getValue('ROW')
   Fc = str(i).zfill(2)
   Col = str(C).zfill(2)
   Row = str(R).zfill(2)
   Fno = str(ID).zfill(3)
   Code = Fc + Col + Row + Fno
row.setValue(idField, Code)
cursor.updateRow(row)
ID += 1
arcpy.Delete_management('grid_lyr')
arcpy.AddMessage("\n\nFinished...")
arcpy.AddMessage("Last ID created: " + Code)
How did the script run if ID isn't defined?..  Code formatting... would help too
SeanPhayakapong2
     for row in cursor:
          selection = arcpy.SelectLayerByAttribute_management(inputLayer, 'NEW_SELECTION', '"FACILITYID" is NULL')
          arcpy.MakeFeatureLayer_management(selection, 'selected_lyr')
          selected_grid = arcpy.SelectLayerByLocation_management (grid_lyr, 'intersect', 'selected_lyr')
          arcpy.MakeFeatureLayer_management(selected_grid, 'selected_grid')
          ID = arcpy.GetCount_management(arcpy.SelectLayerByLocation_management (inputLayer, 'intersect', selected_grid)
                FC = str(i).zfill(2)
          Code = FC + Col + Row + Fno
          ID += 1
     arcpy.Delete_management('selected_lyr')
     arcpy.Delete_management('selected_grid')
SeanPhayakapong2
Great, thank you, I will look more into the fishnet. I think at that point it wont matter if its in order or not as long as its all within each cell.
line 27, indent by 4 spaces
If the above aren't all text or numbers you would be advised to
Code = "{}{}{}{}".format(FC, Col, Row, Fno)
and Code will obviously going into a text field.
