how to remove graphic from view using attribute in 4.6
1699
01-16-2018 09:00 AM
LoriEmerson_McCormack
How can I remove a graphic using an attribute?  I am able to add the graphic.
view.graphics.graphics.length is invalid.  I am having a hard time finding what I need in the view object because of all the _proto_ levels.
//** show Graphic for selected feature **//
function showGraphic(myID) {
   if (arrayIdFeatures.length) {
      for (i = 0; i < arrayIdFeatures.length; i++) {
         if (arrayIdFeatures.attributes['Legend ID'] == myID) {
            var pointAtt = {
               "LegendID": arrayIdFeatures.attributes['Legend ID']
            var pointGeography = arrayIdFeatures.geometry;
            var pointGraphic = new Graphic({
                        geometry: arrayIdFeatures.geometry,
                        symbol: pointSymbol,
                        attributes: pointAtt
                     view.graphics.add(pointGraphic);
         } // end if stmt
      } // end for stmt
   } //end if stmt
} // end function showGraphic()
//** remove Graphic for selected feature **//
function removeGraphic(myID) {
   if (view.graphics.graphics.length) {
      for (i = 0; i < view.graphics.graphics.length; i++) {
         if (view.graphics.graphics.attributes.LegendID == myID) {
                  view.graphics.remove(view.graphics.graphics);
         } // end if stmt
      } // end for stmt
   } //end if stmt
} // end function removeGraphic()
RobertScheitlin__GISP
Lori,
   They way you are working with collections is incorrect. Collections are a bit different than arrays.
      for (i = 0; i < view.graphics.length; i++) {
         if (view.graphics.getItemAt(i).attributes.LegendID == myID) {
             view.graphics.remove(view.graphics.getItemAt(i));
         } // end if stmt
      } // end for stmt
   } //end if stmt
Lori,
         } // end if stmt
      } // end for stmt
   } //end if stmt
Robert,
Thanks for the insight about Collections.  I will learn more about it.
Using view.graphics.length worked.  Also, using view.graphics.getItemAt(I).attributes.<custom attribute> worked.  Brilliant.  Thanks!!
