Export to pdf gives a bad result at certain scales for arc shaped polygons. Idem with PDF Creator, export to png, using arcpy, ...
See images below: purple arc is properly exported at 1:40.000, but not at 1:20.000
Features are stored in arcsde geodatabases.
Has anyone an idea what the problem is?
If the arcsde polygon feature class is saved as a shapefile, the shp polygon is properly exported to pdf, but... no, I won't save all feature classes to shapefile as a workaround.
Thx, Guido
