Survey123 PullData csv updated, form not updated
3632
6
01-15-2018 03:56 PM
YuyingLi
I created a form using pulldata function to identify pole structure specifics when the user select the pole structure from the form. I have to updated the csv file for some minor correction, so I just overwrote the csv in the local media folder of the form, and republish the form. But when I tried the form (I deleted the form on my mobile and re-download it), I still have the wrong data showing in the form even when I open the csv file, the error was corrected? Did I miss anything? Are there any specific steps I need to follow to update the csv file?
Thank you,
Yuying
JohnathanHasthorpe
Hi Yuying - it sounds like you are following the correct workflow and it should result in an update to the form.
Are you able to share the form and .csv (as well as the device, OS and version of Survey123 you are using) and I will try to replicate.
John
YuyingLi
Thank John –
Attached is the csv file…and the screenshot shows the updates –
Yuying Li, GISP
D 858.712.8381
hdrinc.com/follow-us<http://hdrinc.com/follow-us>
JohnathanHasthorpe
Can I have the survey form as well? Thanks
YuyingLi
Here you go –
Yuying
Yuying Li, GISP
D 858.712.8381
YuyingLi
The corrected item is still show in the form –
Yuying Li, GISP
D 858.712.8381
JohnathanHasthorpe
In the diagram above you highlight the select_one serial question. Note that this is a select_one question that is not populated by the pulldata function, it's values are coming from the choices tab.
It looks like your form and method is working - you just need to update your choice list in the xls form.
