Georeferenced image won't show up in Story Map Swipe?
1568
5
01-10-2018 10:09 AM
NikAnderson1
I am trying to create a Story Map Swipe showing a current imagery basemap from ESRI and a georeferenced aerial photo from the 30s. I can see both the imagery and photo in my web map but once I create the Story Map Swipe, I can no longer see the photo.
I am bringing the photo into my web map by hosting it on our Server. As of now the only two items I have in the Story Map are the photo and the basemap.
Any ideas?
RupertEssinger
Esri Alum
Hi. If your web map is publicly shared, would it be possible for you to post the link here so we could try it out.
Rupert
NikAnderson2
http://arcg.is/2qXjFaz
Here is the link, like I said, there should be a georeferenced image from the 30s. Shows up in the Web Map, just not the Story Map.
Thanks Rupert
CarmelConnolly
Hi Nik,
Looks like the web map is referncing a service that's just local to your machine?
http://ntob-gis:6080/arcgis/rest/services/Sauk_badger/ImageServer
The swipe app might be struggling to maintain this connection even though the web map shows it.
Do you have the option of accessing the service from a machine that has IIS installed?
Carmel
RupertEssinger
Esri Alum
The georeferenced image doesn't draw for me in either of the two web maps you are using in this Story Map:
http://www.arcgis.com/home/webmap/viewer.html?webmap=c0b3304076c1421caa39fda33de402d9
http://www.arcgis.com/home/webmap/viewer.html?webmap=3a2e910fbf464709b9aad45145d6e948
Your image service is not accessible over the web via the protocol you are using to access it.
Perhaps contact Esri Tech Support on how best to configure and access that service.
Rupert
NikAnderson1
Yes our server just went offline temporarily, we are working with IT to fix it. I will reply back when its back online. Thanks for the help.
