Is it possible to automate a StoryMap?
1347
01-08-2018 09:12 AM
QJones
I would like to create a story map for a future journey of mine.
But I will not have internet access for the majority of the trip.
What I'd like to do is link my map to my AIS/GPS (my provider has an API available), then when able add pictures and journal logs.
The later seems straightforward but I have found no resources on auto updating map data.
Is what I'm looking to do practical for a neophyte and if so how should I go about setting things up?
RupertEssinger
Esri Alum
Could you describe a bit more what you are looking to do? For example if you are making a Story Map Tour or Story Map Shortlist using photos, those apps will automatically read the geotags in those photos to locate them in your story map.
Rupert
QJones
Certainly, let's see if I can do better.
On a daily basis I would like to fetch coordinates from an AIS system (in xml, csv, json) and add it to a track of previously fetched positions.
Is this out of the scope of StoryMaps and I should be asking in the ArcGIS Online subsection?
RupertEssinger
Esri Alum
Hi, thanks for the update. It would be better to ask in ArcGIS Online subsection because you'd do that mapping in a web map. You could then use that web map in a story map, such as Story Map Journal. ArcGIS Online web maps have several options for adding points from files or feeds.
Rupert
